Mach Discussion => Mach4 General Discussion => Topic started by: Len-Tikular on August 01, 2019, 06:57:20 AM
I would like to install Mach4 hobby License file on anther machine. How many installs are allowed. Do I need another PCID ??
you may have up to five machines, each will have its unique PCID.
Thanks Craig, but how do I get another PCID and Liscene file ?
log on to the NFS site and go to 'self managed licence' section.
Thanks Craig, all set up now!
Now I am ready to connect my Warp9 ESS.
I have opted to stay with my C11 board and will maybe add an addition Break out Board for the extra i/o's
Am I correct in saying I can copy all my motor ports and pins from Mach3 and add them in to my Mach4 setup ?
That is substantially correct. Set up the pins in the ESS/Pins Config tab, then assign the pins on the ESS/Outputs tab.
Note the ESS plugin automatically updates the Mach Control plugin, it should not be necessary to make the settings in both,
just the ESS plugin.
