Mach Discussion => Mach4 General Discussion => Topic started by: jevs on July 31, 2019, 09:35:31 AM
I have to upgrade my pokeys 55 that is used for physical buttons, switches, & Pendant to go to Mach4.
I am wondering about going with the Ethernet version(57e) instead of the USB version (57u)?
Anyone done this? Any details?
Since there is only one ethernet port on the computer I am wondering the best way to go on adding a second one. I am also wanting to make sure there would be no issues with the ESS.
From my understanding the ethernet pokeys may be a bit more reliable than USB?
I use this combination in Mach4 successfully, ESS runs the machine, the PoKeys does my physical buttons and pots (SRO/FRO). I, too, replaced a PoKeys 55 that was on Mach3 when I upgraded to Mach4. I have the PoKeys57e simply connected to an Ethernet switch on my home network, it doesn't require a dedicated NIC like the ESS prefers. I have two Ethernet ports in my PC, one for the ESS and one for the network/internet (GASP!) This combo has been running flawlessly on Mach 4 for a couple years since I sucked it up and switched to Mach4. If you're switching from Mach3 to Mach4, get ready for your machine running much better, but also be prepared for a bit of learning/unlearning!! Mach4 isn't an upgrade to Mach3, it's a total different thing.
If you've written code in Mach3 for your buttons, you'll have to learn a bit of LUA to do it in Mach4, but that said, the PoKeys plugin has many of the buttons you may be using in a tab in the plugin. I haven't tried those because I wrote the code before that tab was in the PoKeys plugin and I haven't taken the time to go back and redo it.
Good Luck, it'll be worth any trouble and DO get the Ethernet PoKeys!
Tom
Thanks for that information!
My computer in my CNC machine is using Wi-fi for internet/network access.
I am using the ethernet port on the back of the motherboard for the ESS.
What do you think is the best way to get my second ethernet port in this scenario?
I want to keep my machine stand alone and not requiring any access to anything to run. It does have internet access and I can access my server etc via the wi-fi, but it will work anywhere without access to anything else.
I will have to solder connectors onto the pokeys57 in my scenario because it is plugged into the Machmotion control panel. That shouldn't be a big deal, but it would be kind of nice to have it seperate if I want to add things to it at some point. I may just get the one with screw terminals and jumper it over so I have better access for upgrades....not sure yet.
I think I will have to supply power to the ethernet version also. I believe this one pulls it from the USB connection.
I have some work ahead of me.
If you have an extra PCIE slot, or something, in the PC, just add a NIC, I'd use Intel but that's just me. Or a USB Ethernet adapter?
You will have to power the PoKeys57e with 5 volts, very easy to come by with a PC close by, you can even get it from a USB port. You could use the same USB cable that's going to the PoKeys55, just cut the end off and find the two power (5v) wires. Or a simple 5v power supply powered from your 110 mains somewhere in the box. I like Meanwell power supplies, but Chinese rips are probably $8.
I notice the Pokeys 57E does not offer keyboard or joystick emulation, but the USB version does.
Is this of any concern?
It wasn't to me, but it may be to you.
I went ahead and ordered the 57e and a PCI-E network card.
