Mach Discussion => Mach4 General Discussion => Topic started by: mcardoso on July 10, 2019, 09:52:13 AM
Hi All,
I don't think I have ever seen my cycle timer work in any version of Mach 4 (I'm at 4162). It is stuck at 0:22 at all times. Is this a common thing? Is it easy to correct?
Mike
Works fine here. Sounds like you may have some customization in the screen or scripts that is breaking it. Have you tested with all things default?
Figured it could be that. I'll load a default profile and try it out.
