Mach Discussion => General Mach Discussion => Topic started by: Steve_Withnell on July 06, 2019, 07:13:48 AM
I'm running a Sieg KX1 with the 4th axis enabled. Mach 3 recognises the 4th axis stepper (drives a rotary table) two Newbie questions;
a) How do I get the Mach 3 main screen to show the axis position in degrees and;
b) What's the best hobby level CAM software to drive the 4th axis?
My setup is a dedicated Dell Optiplex desktop running XPSP3 with networking disabled (i3 processor 4GB RAM 250GB HDD). The apps are Mach 3 (As locked down by Arceurotrade) and CUT2D.
All works really well - should have go into this years ago!
Just want to progress with getting to grips with the 4th axis.
Best regards
Steve
Well I solved a) ! It's just a case of calibrating the axis in the Mach3 config screen. What's really cool is that my manual mill is next to my CNC, so I can mount the rotary table on the manual mill and use Mach 3 to drive it!
So all I need now is to find a s/w package that can recognise/utilise the axis for G-code output.
Regards
Steve
Just some information on configuration.
In Config >General Logic your rotary should be configured as angular.
The motor tuning units are steps per degrees for an angular rotary axis.
NOTE:
Ignore the linear check boxes.
The checkbox for linear/angular only tells an axis not to convert when switching from mm to inch, other than that it has no purpose.
A, B and C are always rotary axis and the DRO shows in terms of degrees.
Example for calculating motor tuning:
For my rotary using micro stepping and a 72 gear ratio:
200 steps / rev X 1 rev /360 degrees = .5555 steps / deg X 10 micro steps X 72 gear ratio=400 steps per unit
Grand Rich, thank you.
Steve
You may find this thread interesting on the 4th axis.
Maybe start at reply #46 in the thread ........
http://www.machsupport.com/forum/index.php/topic,35906.msg245747.html#msg245747
