Mach Discussion => Mach4 General Discussion => Topic started by: HeadyCS on April 20, 2019, 04:21:12 PM
I am looking for a way (in LUA script) to switch an output when G31 (probing) is active.
I looked into the API documentation but found no function where can query the status.
I have read the gcode variables / parameters but also found nothing.
local value = mc.mcCntlGetPoundVar (num inst, num PoundVar)
local Gvalue = mc.mcCntlGetPoundVar (inst, 10) -- G
Gvalue: 1.456e-14
local Gvalue = mc.mcCntlGetPoundVar (inst, 10) -- MOD GROUP 1 4001 // Group 1 // active G-code for motion
Gvalue: 1.0 on G1, G31 movements,
I do not know what the output digitize trigger does. So I searched at google and found this page: https://warp9td.com/index.php/faq/faq-mach4
"Digitize Trigger: This output activates when the Probe is active with a G31/G31.x command."
I tried but there dont switches state on G31. it seems to be for SmoothStepper.
You could try monitoring the state of the control using mcCntlGetState for when it is probing. 102 is File:Run:Probe and 202 is MDI:Run:Probe. You can then activate the output when it is either of these states.
I assume that you want to generate, say, a logic "1" when the probe input is active (i.e. the probe is touching). Why do this in a script, why not just use the probe logic level?
that's exactly what I was looking for, thank you buddy.
if anyone is interested and needs:
local i = 0;
while true do
local name = mc.mcCntlGetStateName(inst, i);
mc.mcCntlSetLastError(inst, "machState: "..tostring(i).." - "..tostring(name))
i = i +1;
if i > 300 then
break;
end;
end;
available mach states (machState, rc = mc.mcCntlGetState(inst);):
machState: 0 - Idle
machState: 1 - Hold
machState: 2 - File:Subroutine
machState: 3 - MDI:Subroutine
machState: 4 - Jogging
machState: 5 - Dry Run
machState: 6 - Homing
machState: 7 - Config
machState: 100 - File:Run
machState: 101 - File:Run:Feed Hold
machState: 102 - File:Run:Probe
machState: 103 - File:Run:Probe:Feed Hold
machState: 104 - File:Run:Threading
machState: 105 - File:Run:Threading:Feed Hold
machState: 106 - File:Run:Feed Hold:Jog
machState: 107 - File:Run:Tapping
machState: 108 - File:Run:Macro Hold
machState: 109 - File:Run:Macro Hold:Jog
machState: 110 - File:Run:Single Block
machState: 111 - File:Run:Retract
machState: 112 - File:Run:Homing
machState: 113 - File:Run:Single Block Hold
machState: 199 - File:Run:Ending
machState: 200 - MDI:Run
machState: 201 - MDI:Run:Feed Hold
machState: 202 - MDI:Run:Probe
machState: 203 - MDI:Run:Probe:Feed Hold
machState: 204 - MDI:Run:Threading
machState: 205 - MDI:Run:Threading:Feed Hold
machState: 206 - MDI:Run:Tapping
machState: 207 - MDI:Run:Macro Hold
machState: 208 - MDI:Run:Macro Hold:Jog
machState: 209 - MDI:Run:Retract
Check the state and store in a variable. Then send message only if it and current state ~=
Stay away from loops when possible and don't spam the core (with 300 unnecessary messages).
