Mach Discussion => General Mach Discussion => Topic started by: billJohn1962 on March 28, 2019, 11:23:01 AM
is there a way to change the x axis direction on the screen in mach 3. currently on my screen when I move the x axis in the positive direction the cursor moves from left to right but I would like the cursor to move from right to left in the positive direction. I have played with reversing the motors and reversing in homing/limits and the screen allways moves from left to right?
X axis moving in positive direction should be left to right - that is the correct convention.
Tell us why do you want to change that as changing to something wrong is easy.
(see attached)
with this machine the operators station is in the front of the table the table is 6 feet wide and 20 feet long ( the x axis ) well the x axis is parrelel to the wall and back of the operators station is against the same wall so when he is standing at the station facing the monitor the table is to his left if he looks over his left shoulder he is looking down the 20 foot length on this machine when he moves the x axis it is moving away from him in the positive movement I would like the screen to accurtly depict what the movement is on the screen the table is moving right to left so the cross hairs should move right to left is why I am wanting to do this
In your situation,
x=0 should be far left corner so you should simple invert the x-axis so that x++ is coming nearer.
ok another thing about this machine it only has one prox switch on the x axis and one for the y axis which is located at the front of the machine the end closest to the operator after it does a ref all home it uses soft limits to know the extents of the machine your suggestion puts the home x-0 and y-0 at the far end the end furthest from the prox switches it moves proper when moving down the machine it moves in a positive ( away from the operator ) it is only depicted wrong on the screen for this particular application I guess one answer could be to turn the operaters station around 180 degrees then it would all be faced right but that is not really practical either for this situation all works I would think there would be a simple setting in mach3 to reverse the motion on the screen only but I cant find that one
You can use Home Offsets in Config>Homing/Limits to move the 0,0 home position relative to the switches.
All CAD/CAM drawings Cartesian coordinates convention, x0 has to be at the left corner of table. That should also be the machine coordinates. YOU should not change that.
If you reference home as you are doing, you could set X to length of table (say +240 inch) and NOT zero. So when you g0 x0, spindle head moves away to far end.
If you set that to zero, then your gcodes must have all negative values of x.
I would just move my x axis proximity switch or do what Gerry said.
Then redefine tool change location to x=240, y=0
ok I got it figured out was beating my head against the wall for nothing as it turns out everything was right in mach 3 when a file is created in sheetcam and I locate my 0,0 corner in the lower right hand corner the cut is in the negative not the positive
If it is me,
I would swap x and the y axis and keep x0 y0 at nearest left corner so that it is easier for others to understand when jogging with a pendant or arrow keys.
