Mach Discussion => Mach4 General Discussion => Topic started by: Vivek on February 28, 2019, 09:48:46 AM
I get a homing error when I press the home button. "###Homing Error###. Motor:2 is not enabled" and I really don't know what I need to do in order to fix that.
Sincerely,
Vivek
that error is telling you that the code executing the homing routine is asking for the axis powered by motor 2 to drive
to its home switch. Clearly you do not have a motor 2.
Most people with a mill or router assign:
motor 0=X axis
motor 1=Y axis
motor 2=Z axis
With a lathe:
motor 0=X axis
motor 1=Z axis
and there is NO motor 2.
Two ways to skin this cat:
1) In configure/Control/Axis_Mapping assign a motor 2, even if you don't have one.....and set that axis to 'Home in Place'
in the Configure/Control/Homing-Softlimits page
2) In the Configure/Control/Homing-Softlimits page assign '0' the Home_order of the unused axis.
Also check
Configure->Control->Motors And make sure the check boxes are checked by all of the motors that you use.
Steve
I am replacing all the motors and drive and pretty much stripping down my machine. I have two motors on x axis, one on y and z axis each. I am using Hicon controller. I have checked all the boxes making sure the motor have been enabled. I can move the motors using the jog feature. It still says motor 0 and motor 2 not not enabled when I press the home button. Would it help more if I send the pictures of all my settings.
Vivek
