Mach Discussion => Mach4 General Discussion => Topic started by: JustinLloyd on February 24, 2019, 07:42:30 PM
I have a NextWave Automation Piranha FX CNC from mid-2015 that I've been very happy with and have developed a couple of custom applications for. I am going to write a driver plugin for Mach4 that will run the CNC - let's face it, the NextWave Control Panel was a bad joke but it at least let me figure out how to communicate directly with the Piranha CNC. I have been playing around with Mach4 and it seems to do what I want as an application. Now I just need to glue the two parts (Piranha CNC and Mach4) together.
I understand I can script Mach4 in Lua. I also understand there is an SDK/API for Mach4. I am assuming that the Lua script API has certain limitations such as creating a new hardware driver so the native SDK will be a better option.
I've poked around the Mach4 website, and I am probably overlooking something obvious, but I don't see any mention of an SDK or anywhere to download an SDK. Google search doesn't seem to throw anything up either, other than these forums.
Anybody have a "click this link dumb****" for a next step?
Please ignore my message. I seem to have found it by simply looking in the Program Files directory.
That was surprisingly easy. Mach4 jog function controlling Piranha FX implemented. On to the next task, touch plate detection.
Jog, GCode download, all four axes, touch plate detection, Idle, Hold, E-stop, and a few other bits all done and working on the Piranha FX. I am not sure what else I need to add at this point.
I should probably go and buy a copy of Mach4 Hobby now.
Thank you New Fangled for making an API that was easy to work with.
