Mach Discussion => General Mach Discussion => Topic started by: Fred_evans on January 28, 2019, 02:16:22 PM
Hello Chaps
I have just had a 3rd axis fitted to my lathe .
I have been using the 1024 lset screen and now I believe I must use the 1024.set screen ( milling)
so that the 3rd axis can be used.
Using the 1024 .set screen is it still possible to jog the axes using the up and down and sideways arrows?
how can i jog the 3rd axis?
many thanks
fred
Config. / System Hotkeys
Select the axis then press the keyboard keys of your choice.
(Make sure the axis is enabled in settings).
My Mach guru has set it up so i can jog 3rd axis using the page up and page down arrows
regards and thanks to all
Fred
