Mach Discussion => Mach4 General Discussion => Topic started by: Raymondo on November 29, 2018, 03:53:06 AM
Hi
I have ordered a ESS and C82
But I have been looking through the Mach4 software will I await its arrival and it occurs to me in the control panel the inputs section the Probe 0 to 3 probes are dedicated and can't be assigned to other inputs is that correct ?
If that is correct I assume the ESS smooth stepper board will also have the dedicated input to match
The same apply to E stop and the XYZ home switchs
is Probe able to use any input if so where do you configure it
Regards Ray
the ESS has a total of 51 inputs/outputs.
You could dedicate 4 inputs to Probe1, Probe2.....Probe4 for instance. Note that Probe1, Probe2 etc are Mach4 inputs.
How many of them you use, if any at all, is up to you. If you want to use G31.X probing commands then Mach will
look at ISIG_PROBEX as the probe contact event.
For instance:
G31.2 Z -5 F50 will cause your machine to probe in its current XY location to a lowest of Z= -5mm at a speed of 50mm/min.
Mach will monitor ISIG_PROBE2 for the probe contact event. I suppose you could use ISIG_PROBE2 as a signal to do something
else, turn a light ON or OFF say but why?
Hi
I will only use one probe but in the mach4 control panel it has all the inputs listed then lists probe and E stop but what if I wanted to use input #1 as the probe input or does ESS have a input marked probe and I have to use that one for probe
if it does that fine and what I will do
But if it does not how would I assign input one to read as probe
Regards Ray
Hi Ray,
The ESS documentation, including setting up a probe with Mach4 is here; https://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach4#EssProbing
(Although reading all the Warp9 and ESS documentation is bit of a bore it pays to skip through as much of it as you can looking for things current of interest).
