Hello everyone: I have been working on the stability of Mach 3 for awhile. I started out with windows 7 and a laptop without good results. I had problems with inconsistent Z moves. mach wanted to reset zero all over the place one time and then cut fine the next. This was very frustrating. I now have a dual core 3.2 GHZ dell with 4 GB of ram. Standard on board video running on XP Pro. I am also running a Novuson NVEM Ethernet controller. (Mach version 3.043) I ran the first part with multiple profiles (letters) and it ran the first 3 letters fine and failed to stop on the G31 command (top of plate routine) on the 4th letter. This was odd. I went to the diagnostic screen and the probe light was on. I just rewound the program and hit start and it ran with out a hitch 5 times. The 6th time I over-road the feed bumped it to 70 inches a minute and it ran past the probe switch on the 8th letter. Again I just rewound the program, restarted and it ran flawlessly several times. I then bumped the feed down again and it ran past the probe switch again. After rewinding and restarting again it was ok. I have gone in and changed the start up to open nothing upon windows startup and erased several non essential programs. What am I missing? I can include some G code but this must run deeper than the code. should I create a macro with wait states in it to keep the computer in check? Can anyone help me here I am stumped. and very frustrated not being able to run a part reliably. Is Mach 3 simply an unreliable program!!!!! :-\
