Mach Discussion => Mach4 General Discussion => Topic started by: Thinder on October 20, 2018, 06:02:08 PM
Im working on my M6 Macro. Its a simple one with no automatic touch off. But it misses the first tool change. In other words the first T* M6 that it comes across it shows that the tool selected is the same as the tool being used and misses the tool change. On the second T* M6 it catches it and functions normally.
Im pretty sure ive got something out of order but I cant seem to see it. Here is a screen shot
Just a little more info. when I debug, and hold the mouse over my variabls it shows 'nil'
Make sure your the settings in the config dialog are correct. e.g. T on M6 line is too to use.
Steve
Steve
AAAnd we're over my head! Config Dialog is where? If you mean make sure that Mach 4 is displaying Tool 1 when I select tool 2 and I dont already have tool 2 displayed. Then yes, its showing a different tool than the tool i am requesting.
Another wierd thing is that mcGetInstance() isnt changing color like the other functions when i type it in and it doesnt show "mcgetinstance" the dialog box as a possible function
Steve is talking about the control configuration. Where you change settings in the Mach config, inputs, outputs, motor tuning, etc. There is a tab called "tools". That is the tab Steve is referring to.
Steve
HOly $h*t you guys are genius! That was it!. I didn't even know that was a setting in MAch 4! I figured precalling a tool was done in the previous line!
Thanks guys!
Yup. Gotta make sure it is set correctly.
First time I needed this setting changed Steve helped me out. I made a Tool Pre Change Macro and had to change this setting.
Glad you got it working!!
