Mach Discussion => General Mach Discussion => Topic started by: gmduke on March 26, 2006, 10:11:48 AM
I would like to run a macropump to fire a lubrication pump to oil the ways of the machine.
Is there a function tied to the Maintenance statistics ?
The total distance the axles travel would be allot better then a timer to fire the lube pump.
Any ideas on this are welcomed.
Gerald
I will see if there are any calls to get the data.
Art is adding the calls :)
Hi Brian
Can you post the New call or calls maybe there is a list of all the calls available, if there is can you tell me where I can find them?
Gerald
Email: gmduke1@earthlink.net
Any word on the macropump? I am looking to do the same thing. Just finished all the plumbing...
Robert
