Mach Discussion => General Mach Discussion => Topic started by: StuartW on August 08, 2018, 04:04:08 AM
Hi there newbie here I have a Maxi cut 1325 table I am running Win7 32bit.
Revolutionary 3 Axis Mach3 CNC USB Motion Controller Card 200KHz Stepper Servo. From Ebay
Compatible 3.7 hp air cooled spindle with a Delta VFD.
I had a friend help convert over from a DSP controller. I am having an issuue with the vfd pulsing for a start and a different readout from mach3 to vfd panel
xyz are working.
I would like to reinstall Mach3 correctly from the start again, and get rid of all the bugs. Where should I look for documentation and help.
All help appreciated. regards Stuart
Not certain which bugs you are referring to but...
Make a backup copy of your existing Mach3 folder (to keep a record of your settings) then download Mach3 from here; http://www.machsupport.com/software/downloads-updates/
It can be installed over the top of your existing version.
Thank you for your reply. I have a issue as the spindle speed goes up so does the speed of X and Y, to the point I shut down as the movement is very erratic plus the vfd is pulsating at low speed and at the same time also the x and y. regards Stuart
I suspect that may be a problem with your Motion Controller rather than a problem with Mach3 itself. It will be interesting to see if the problem persists after you have completed the re-install.
Yes the main issue was fixed after new install, still need to sort out vfd speed, will wait till i get new ATC spindle and vfd. Up until then i will manually start spindle.
