Mach Discussion => Mach4 General Discussion => Topic started by: KatzYaakov on June 26, 2018, 12:40:30 PM
hi
in mach scripting manual there sample of probe cycle
the input signal is: ISIG_DIGITIZE
but in there help manual there the list of all signal but no such signal name
and the probe signal input is:ISIG_PROBE
the signal is very iportant i can use other input because the use of G31
thanks
its actually the motion controller/BoB that does the probing, or least the time critical parts of it.
To my knowledge ALL the motion controller manufacturers have used ISIG_PROBE name of the
probe input pin.
DIGITIZE was a term that came from Mach3, I don't recall ever seeing it in Mach4 or any Mach4 documentation.
The probe input was named ISIG_DIGITIZE in earlier versions of Mach4, but was later renamed to ISIG_PROBE. This relates to G31.0. G31.1-3 are similarly now given the more intuitive names of ISIG_PROBE1 to ISIG_PROBE3.
These are defined in machine.ini
Allan
