Mach Discussion => Mach4 General Discussion => Topic started by: jpkkmo on June 19, 2018, 09:21:13 AM
Hello,
I'm using Mach4 on a 3 axis CNC router; machining long run (8+ hour) jobs.
I'm sure it's already been discussed elsewhere here before... if I wanted to completely power down Mach4 and the machine, and restart from where I left off, what's the best way to go about it? For example, if a storm comes up I would like to shut down to avoid an outage, or can only machine 3 hours into an 8 hour job and want to restart where I left off.
Is it possible to do a FEED HOLD / Power everything off / Power everything on / CYCLE START ?
Thank you for your help!
No.
You will need to remember where you left off and then do a run from here when you start up again.
Mike
I have had good luck with "Run from here", other people say it is temperamental.
There was a post on here that had a little bit of a discussion about it but I'm not having any luck finding it right now.
Actually, thinking about it, Bryanna could make a video on "Run from here" to show people how to use it properly. Just a thought.
I have used run from here and it is much better in Mach4 than it was in Mach3.
+1 on the video idea.
Mike
Thank you for the feedback Mike & Cbyrdtopper!
