Mach Discussion => General Mach Discussion => Topic started by: Ted Kelley on June 06, 2018, 05:10:06 PM
Hi my name is Ted Kelley and I am a newbie.
I got ahold of a pirated copy of Mach 3, and had a very hard time getting rid of it. I would uninstall it and load a "good" copy off Artsoft's website and the leftovers from the pirated program would corrupt the new copy.
My son came over last night and worked his magic and cleaned a the bad leftovers off you machine. I downloaded Mach 3 again from Artsoft and it came in clean. I have bought the license and now it is licensed to me.
I and using a UC100 CNC Motion Controller. When I installed the Mach 3 program I deselected the Parallel port driver. I had red somewhere that is did not need it when using the UC100 CNC Motion Controller.
Did I mess up? I do not get a blue light on the UC100 and now the motors do not move. All of that was working with the pirated program.
When I look at the USB ports in device manager is says that the device is work correctly. Help
Hi Ted,
Welcome.
Sorry to hear of your experience with the Mach3 pirates.
Not wishing to add to your woe's but do you have a genuine version of the UC100 ? (if, for example it is in a metal casing then it is fake).
The blue light means the UC100 is "talking" to Mach3.
You probably just need to change some settings?
Hi Ted,
Did you install the UC100 plugin on your new copy of Mach3? If not you can download it from CNCDrive at the link below. Once it's installed, open Mach3 and select the UC100 as your motion controller. If you're not given that option at startup, go to Function Cfg's and pick Reset Device Sel(ection), then restart Mach3. Once it loads, you'll have the option to select the UC100.
http://cncdrive.com/UC100.html
-Bryanna
Thanks everyone. reloading the UV100 software was whit I needed. All is well.
