Mach Discussion => Mach4 General Discussion => Topic started by: Analias on March 17, 2018, 01:07:57 AM
Is there a way to enable and control tabbing between a set of UI controls? As an example, if I add X, Y, Z, and A axis DROs to a screen set can I enable tabbing between these four DROs so that they move from the X, to the Y, to the Z, to the A, and back up to the X?
I don't see any mechanism for enabling or setting the tab order like you can with other development tools.
-Freeman
