Mach Discussion => General Mach Discussion => Topic started by: Letomoto on March 16, 2018, 01:25:46 PM
Title: Homing operation does not pulls back enough to get away from switch?
Post by: Letomoto on March 16, 2018, 01:25:46 PM
Hello i am fighting a pretty annoying problem on my benchmill i installed a 3 axis kit on , just installed switches for limit and homing
i installed limit switches but they are  industrial NO/NC switches , spring loaded contacts wich have quite a lot of travel in them
 - the machine sees every signals correctly
-the cables are shielded and grounded
- if i disable the limit switches input  it homes and backups fine
- if i disable the home switches pins the limits stops the machine like they should
- if i have all the inputs enabled the machine will home one axis back off and sometimes just not pulling back from the switch enough to bring back the NO switch in open position and then it locks the machine .probably the travel needed times out the homing routine and gets out of the homing operation still on the limit switch locking the machine
-i did install capacitors to clear a potential noise problem but it isnt the case apparently
The axises sometimes clicks and unclicks the switches well but sometimes it doesnt so it is not constant. i can just push a bit on the carriage or the tab the switch sits on and i make it unclick from her activated position so looks like the travel of the homing back off is about a few thousands too short . i tried giving a bit more of acceleration to the axises but it is not helping.
so now i am trying to figure out if there is a way to edit the amount of distance the homing operation has to recognise the home switch click back out ??
tried modifying a few values in the homing setup screen and it didnt helped :-(
Title: Re: Homing operation does not pulls back enough to get away from switch?
Post by: joeaverage on March 16, 2018, 07:19:18 PM
my recommendation, and will see if you read any of my other posts, repeatedly make the case foe separate home switches.
Leave all your existing switches in place but as limit switches only. Get another three switches an fit them as Home switches alone. It avoids all the
trouble that you are talking about.
Note that its not necessary to have a home switch at the very end of travel. Its common to have them just in from the end, a few mm or more, but they
don't have to be.
Post by: Letomoto on March 16, 2018, 08:41:14 PM
well i got some micro switches at the store today , most people seemed to have success with their combined switches so i was trying to understand why the hell i wasnt able to , so yeah simply add more switches will definately work , i can also just take my wires from the switches i already installed no need to rewire
Post by: joeaverage on March 16, 2018, 08:52:38 PM
in Machs early days everyone used a parallel port and need to be very frugal with inputs, theres oly five in a parallel port. Combining limit and home switches
was required. It caused problems with compatibility then and it still does now.
With extra BoBs and external motion controllers as cheap as they are theres no need to do it any more.
Post by: joeaverage on March 17, 2018, 02:22:51 AM
a lot of switches, including snap action microswitches have hysteresis. It means that the switch makes at position x=0 but when it unmakes it has to travel
a bit further say x=-0.1. For home switches this is a good thing.
When Mach homes an axis it drives to the home switch in the direction and speed that you specify on the setup page until the switch makes. When the switch makes Mach
will stop and back up until the switch unmakes, ie the hysteresis distance. You've already noted that if that distance is too small it is possible for flexure in the machine to cause the
switch to re-trigger. Thus for home switch a small but repeatable hysteresis is desirable.
Note that switches with vanishing small hysteresis are available but are expensive and actually unsuitable for this purpose.
I not also in your post that when you set the Home Off distance on the setup page you expected the axis to drive backwards that distance. Mach doesn't do that.
What Mach does in fact is drive until the switch makes, then reverse until the switch unmakes and then set the machine coordinate of the axis to zero if no
Home Off distance is specified or the Home Off distance if it is specified. Note Mach DOES NOT drive to that remote location, it just sets the machine coordinates
to some remote location.
This has caused a lot of confusion over the years. Note also just to complicate matters a bit there is at least one external motion control board (PoKeys) that
can drive to that remote location if you program it to do so. It is not standard Mach behavior. Note also that with a macro you can cause Mach to go to a remote
location and achieve the same result, it just requires a short program.
Post by: Davek0974 on March 17, 2018, 03:51:40 AM
If this is a stepper system, simply use one of your existing switches on each axis (at the home end) as a home switch, forget limits they are not needed on a stepper drive.
disconnect the other switches.
configure Mach to HOME input only, not limit or combined, get the machine homing correctly and then turn on soft limits, job done.
Post by: Filou on April 04, 2018, 12:17:46 PM
" ... forget limits they are not needed on a stepper drive".
the simplification you are proposing presents the advantage of simplicity. How do you motivate this choice ?
Post by: Davek0974 on April 04, 2018, 03:10:02 PM
Unless you are running geared reduction or high reduction belt drives, i.e. an unusual setup, the steppers do not have the power to do too much damage if they run away or you jog into the end stop.
I would always go for a home switch on each axis, correctly set soft-limits on each axis and thats it, simple and easy. When set correctly soft-limits are the perfect answer - less wiring, less hardware, less hassle.
On a servo drive then no, hard limits AND soft-limits all the way - theres some awesome destructive power in a servo of reasonable size and you really do not want that smashing the ends off your mill table etc.
Post by: Filou on April 04, 2018, 04:25:51 PM
Davek0974, all right, your argument leverages on the "limited" power of stepper motors AND on the presence of sufficiently strong end stops.
Here the story of a (thus far unique) unexplained event that convinces me to combine HW AND soft limits on a open loop rig without encoders. On a long job, about a square meter of working area, one axis gets a sudden shift of about 200 mm. I double checked (after the "crash" into the support) that this shift WAS NOT in the G-code in the form of a global or fixture offset. The axis passed beyond it SW limit (don't ask me why/how) and was stopped by the hardware limit switch placed 3 cm before the physical limit of this axis.
Without this switch, I agree that the damage (to the machine) would have been limited, but the job would not have stopped and the work piece would have been wasted.
Has anyone else experienced "sudden unexplained" shifts ?
Post by: Davek0974 on April 04, 2018, 04:42:25 PM
Interesting, no, i have never seen a sudden shift like that, especially going past soft limits.
Post by: joeaverage on April 04, 2018, 06:47:22 PM
this is not really about combining limits and softlimits its about combining 'home switches' with 'limit switches'
I have always argued they should be separate. If you decide you need limit switches by all means put them there
but separately, ie they should not try to be home switches as well.
Post by: Tweakie.CNC on April 05, 2018, 10:37:48 AM
Hi Philippe,
Are you using a genuine Mach3 license that is registered in your name ?
Post by: Filou on April 05, 2018, 11:41:10 AM
Good evening Tweakie, yes, my license is registered in my name, no cheating. I suppose you are asking about the "strange shift".
I'm trying to reproduce this unique (but scary) event, but have failed thus far.  The job ROI was well confined within range defined by the soft limits. I was not next to the rig when it happened, but I heard the "crash" in one of the supports. I ran to the machine and saw one support holding the work piece pulled off, and the machine nicely going further  with a lateral shift of about 200 mm. On the next direction change (surfacing job) it passed soft limits and was stopped by HW limits that I have wired SEPARATELY from the homing devices, as Colleague "joeaverage" advertises vehemently.
Enjoy your day/evening, Philippe
Post by: Filou on April 06, 2018, 08:38:55 AM
this is today the second event of Mach3 driving BEYOND one of the soft limits. Crash, minor damage. Thank you hardware limits, mounted and wired separately from the homing devices, etc. Driving axis off of limit, cleaning up the mess, and jogging to the home of this particular axis shows a shift of dY = 180 mm, in MACHINE COORDINATES and a minor
dX of 23 mm.
Now, if for some reason, the machine coordinate value of one axis shifts by a certain amount, the soft limit will trigger before or after, depending on the sign of the shift.
Which mechanism can produce such a shift ?
Am I the only fellow with this issue ?
Two events of that sort in one week after more than a year of smooth operation is a good statistics ... waiting for a shift in Z !!
Comments are welcome.
Philippe
Post by: ger21 on April 06, 2018, 09:16:14 AM
There's a bit more to it then that. You have to consider inertia. Think of a battering ram. It's not the speed it's moving at, but the weight that's moving. The moving mass has far more power than the stepper motors.
If you jog an axis up against the stops, and then jog into the stops, the force is only what the motors can deliver. Now run into it at high speed, and the force is much higher.
Sort of like placing a brick on a glass table, vs dropping it on the glass table from 10 ft up. Big difference.
Post by: Filou on April 06, 2018, 10:58:48 AM
Gerry, you are absolutely right, its called kinetic energy, the exact amount of which must be dissipated by the "stop" or some sort of "brake".
