Mach Discussion => Mach4 General Discussion => Topic started by: arhimedoffs on March 10, 2018, 03:22:15 AM
I use script for motor remapping (CNC has two carriage on X axis)
function cnc2plc:selectX1()
-- Disable X axis, unmap Motor2, map Motor1, reenable X axis
local rc = mc.mcCntlConfigStart(inst)
if rc ~= 0 then
mc.mcCntlSetLastError(inst, "Failed to switch axis!")
return
end
rc = mc.mcAxisUnmapMotors(inst, mc.X_AXIS)
rc = mc.mcAxisMapMotor(inst, mc.X_AXIS, mc.MOTOR1)
mc.mcProfileSave(inst)
mc.mcCntlConfigStop(inst)
mc.mcCntlSetLastError(inst, "Selected axis X1")
end
All work in metric units, but after motor switched JOG start working in imperial. All DRO still in mm, and G21 is still active. I reexecute G21 from MDI, and JOG start working normally :)
Mach4 Hobby 4.2.0.3481, same issue with ESS motion controller and simulator.
I think this issue results from the configuration. You could try a later version to see if it has been fixed. or you might try issuing the following after configuration and prior to jogging:
local defUnits = mc.mcCntlGetUnitsDefault(inst)
rc = mc.mcJogSetUnitsMode(inst, axis, defUnits)
Allan
Yes, this works. All fine if I do this for all my axises.
One more question: where find full documentation on API? There is not documentation about mcJogSetUnitsMode in Docs, but it is in all *.exe and plugins headers.
As I found, my code change SetDefaultUnitsOnStart from 1 to 0. What can cause this change?
Look at:
C:\Mach4Hobby\Docs\Mach4CoreAPI.chm
You may need to install a viewer such as xchm to read this file.
I'm not sure why DefUnits would change, but you could assume 21 to force metric for jogging:
rc = mc.mcJogSetUnitsMode(inst, axis, 21)
Allan
There is nothing about mcJogSetUnitsMode. And some other functions not described, but exists in Lua interface.
Sadly the documentation tends to lag behind development - a consequence of the low price of Mach4.
Sorry I cannot remember where I found the above API call. I assume it must have been in a forum post or in the change notes, but I've just done a quick search and nothing showed up.
Allan
Great thanks for trick! It work and I will use it. (One more variant - call G21 via MDI execute from same script, but it slower).
Glad it worked for you.
I assume (why I'm not sure) that issuing G21 sets the current units mode to metric. If you're inclined, you could test this using mcCntlGetUnitsCurrent().
Allan
I had another look and found mention of mcJogSetUnitsMode() in the change log on the ftp site, so I guess that is where I found it.
There was no detail as to its use so I would just test it and fix any errors as they occurred.
Allan
Thanks, good resource for some reading.
And about builds. Latest build from site 3481, but on ftp much more fresh. What about stability and practical usage of newer builds, any experience?
I've often used the latest development builds without any problems at all, but obviously do this at your own risk and be ready with the eStop just in case.
Allan
