Mach Discussion => General Mach Discussion => Topic started by: wilfoude on March 07, 2018, 09:30:43 AM
Hello everyone,
Some time ago I installed a LPT2 card and a pendant in Mach3. The Usual stuff. All seemed to work fine.
Then I found out that some times (if not often) the wrong axis is moving when turning the MPG.
Using the Diagnostics window in Mach3, I found out that the pin status is correct and matches the setting of the X,Y,Z pendant knob.
I tried debouncing the X,Y,Z LPT2 input contacts, but to no avail.
Has anyone any idea what causes this phenomenon and how I can solve it ?
wilfoude
what pendant is it? Do you have a manual?
I have a VistaCNC unit and it is connected via USB to the PC and so doesn't require a parallel port at all.
Helo Craig,
I have a "Propendant", which is the most ordinary pendent you can imagine. Just the case, the switches and the wires. It is to be connected to the LPT2.
It works OK most of the time, but sometimes the internal Mach3 settings for which axis is to be controlled, get out of phase with the settings of the axis knob on the pendant.
The pendant itself seems OK, as can be seen from the diagnostic screen.
I know there are many other pendants available, but like to know what is going wrong here.
Best regards
Wilfried.
do you have a manual? A circuit diagram? A picture? Anything?
I'm not a crystal ball gazer.
Hello Graig,
I fear you are thinking along the wrong track. The hardware of the pendant is OK.
That is proven by the fact that the diagnostic Window of Mach3 shows the correct LED's lighting up when the axis-knob is turned.
The problem obvious is the handling of these settings within the "brains" of Mach3. There the internal variable representing the axis to move gets out of sync with the input status of the relevant oem# pin.
Best regards,
BTW: The relevant part of the ProPendant consists of a 5 way rotary switch. In each of the positions 2 to 5, the relevant contact is connected to common (0V).
In Mac3 the oem#1,2,3,4 Pins are set to "Enabled" and "Active low". That's all.
would be helpful if you post your brain/script witch controls the axis selction.
fine if its not hardware then its software, post that.
No one can help what we cant see.
Hello,
This is the simple brain I use to control the X-axis.
Hope this helps.
Best regards
Wilfried.
ok there is not much what can go wrong in this brain.
i have no idea why this is Happening.
i would in a first step add a and to eatch rung
oemtrigger1 AND LED15(step mode) AND LED83 (Jog on) = MPG1 JogX
Thomas
Centroid Wireless MPG for Acorn CNC Control System CWP-4
Will this pendant Work with Mach3?
