Mach Discussion => Mach4 General Discussion => Topic started by: sour kraut on February 13, 2018, 12:00:34 AM
Very random question. I know that the subroutine's O# or name must match the main files O# but can you call said subroutine from inside a macro? What if I would need to call multiple subroutines from inside of a file? Is it possible to have it open a different O# subroutine?
Thanks.
Your question is a little bit confusing. O# are used in gcode files, macros use function calls. Could you restate the question so we know whether your trying to execute gcode files from a macro or another macro or anther function in the same macro?
RT
Sorry, it was a late night last night. If I choose to store a subroutine outside of the main file, it is my understanding that the subroutine must be named using the O# convention. What I’m wondering is two fold. First, can I call a subroutine that is stored outside of the main file from inside a macro? Second, from reading another forum post (sorry not sure which one) it sounded like I can only call one subroutine stored outside of the main file when using hobby. Is this true or did I misunderstand.
sour kraut, to make it easier for you to learn get Peter Smid book on macros, I am quite sure you can not use maros at all in Mach4
dude1, don't let my number of posts fool you, I've been working with industrial CNC routers for almost 20 years now so I understand macro programming but it's might be a nice read either way. You might be thinking about Macro B which can only be run on the industrial version but you can write your own macros using Lua. Each Profile in the Mach4Hobby directory has a subfolder called Macros where you can store them. I only asked this because I travel for a living and am not at home this week to test this out.
There are multiple definitions of a macro. If your gcode had a m900, what would your m900.mcs code contain? Please provide a simplified example and we may be able to better answer how your definition of macro differs from Mach4's.
RT
WARNING THIS IS MY OWN UNDERSTANDING AND MAY, IN FACT PROBABLY,IS WRONG
If you have a Gcode file which includes one or more subroutines O#, and one or more macros M# then the main Gcode file can execute any of the
subroutines but the macros cannot.
The reasoning given was that the macro is in a sense a subroutine in itself. Thus the parent program, the Gcode file, calls a macro which attempts to
call a subroutine but that subroutine is defined in the parent and the call will fail. 'A parent can call on a child or children but a child cannot call on a parent'
Using this logic if a macro has a subroutine defined within itself it could be called successfully.
If you wish code to be called against the hierarchy then that code could/should be put in a panel.
Some days it pays to stay off the internet. I responded in the wrong post.
http://www.machsupport.com/forum/index.php/topic,36577.msg250891.html#msg250891
Findings:
A subroutine can call a macro, and a macro can call a subroutine but more testing is needed.
