Mach Discussion => Mach4 General Discussion => Topic started by: Overloaded on January 30, 2018, 10:36:12 AM
Lathe, Diameter Mode
Inc. Jog Step = 0.0010
The X MACHINE DRO increments 0.0010
The X PART DRO increments .0020
Shouldn't the Machine dro increment by 0.0005 ?
and the Part dro by 0.0010 ?
If it should be changed, where/how (roughly) would one go about it.
Russ
When in diameter mode I think that if you jog .001 then the DRO should indicate .001 and the tool should move .0005 IMHO.
Precisely ;) THANKS !
Just need to figure/learn how to fix it.
It needs to divide the increment by 2 for the MACHINE DRO instead of multiplying it by 2 for the PART DRO.
Thanks again,
Russ
I don't think you can change that behavior. Probably best to open a ticket with NFS on this one.
I also noticed this inconvenience. in diameter mode the displacements with Jog take twice the value.
