Mach Discussion => General Mach Discussion => Topic started by: lew on July 05, 2007, 07:50:54 PM
Hi All:
I'm experimenting with messages to the operator from within the Gcode.
For example, i will program an M01 pause and put a message in the program to "change the part".
While this message shows up on the Status label, it does not go away.
Is there a way to clear the Status label from within the program and after the cycle is started again?
LEW
Try this:
a line or 2 later
basically a message with no characters. My machine is down now so I can't try it, but I don't see why it won't work
Mark
Thanks, Mark:
I should have thought of that. It's a really simple fix. It works very well. I actually used this:
(change the part)
m01
LEW
