Mach Discussion => General Mach Discussion => Topic started by: Leadhead on December 07, 2017, 04:35:45 AM
Title: Mach3 turn tool form
Post by: Leadhead on December 07, 2017, 04:35:45 AM
I would like to use my grooving tool (MGMN200) 2mm across with 2x 0.2mm corner rads.
If I wished to cut a sphere using both sides of the tool. Can I tell M3Turn the shape to be used "as a one piece tool", as opposed to generating a R/H & L/H toolpath which I do currently?
Any advise gratefully received.
Title: Re: Mach3 turn tool form
Post by: RICH on December 07, 2017, 10:09:46 AM
You can use any tool you wish it all depends on how it is defined and what software you are using to generate the code.
Practically though, I would not use that tool since there will probably be gouging.
Try LazyTurn and see what pathing is generated.
Post by: Leadhead on December 07, 2017, 10:29:37 AM
Rich - Sorry got confused between my CAM and M/C software.
