Mach Discussion => General Mach Discussion => Topic started by: npalen on November 21, 2017, 10:38:30 AM
Hello from a newby. I've been running Mach2 and then Mach3 for about 15 years or so on a CNC router. (modified Techno-Isel) I'm a retired design engineer/machinist.
Have a question on the Mach3 digitizing routine that is listed on the top menu. When trying to run it I get the error "PREVIOUS SEQUENCE NOT YET COMPLETE". If I press the "OK" button on the error message box continuously it will move on the x and y axis every third press but nothing happens on the z axis. Have checked the probe input and it shows okay.
Can anyone help me out on this? I've used the digitizing wizard add on many times with success but would like to try the Mach3 menu digitizer. Thanks
I think you must be looking at a very old version of Mach3.
As far as I know the Wizard replaced the menu version many years back.
Yes, very old version of Mach3. Would update but my darn old pc used for Mach3 won't connect to my router so I can get on the web. Need to get that issue fixed. :)
Would like to find and use a digitizing routine like the Mach3 Wizard but want to be able to move up in Z only slightly after each hit and then move in X or Y for the next probe to save time. This would be as opposed to moving up to Z0 each time. Would you know of such a routine that could be used in Mach3?
My workshop PC does not connect to the net so I download Mach on this PC then copy the installation.exe file to a USB memory stick then use that to transfer the installation.exe to the workshop PC.
Sorry but Digitizing is not something I have ever done so can't be much help regarding reduction of the Z axis clearance move.
So when updating Mach3 does it retain all of the settings?
If you install the new version over the top of the existing version then yes all the settings are retained. However, it always pays to keep a copy of your existing Mach3 folder just in case.
I downloaded a new copy of Mach3 but I'm still seeing the old menu version of digitizing. Would that be because I copied my mill.xml file over? I noticed that the xml file has parameters in it that show up in the menu version and wondering if that is why it still shows in the menu.
Could be that you are still using your original Screen.set
In the Menu View / Load Screens select 1024.set for the standard screen.
Got that fixed now. Thanks for your help!
