Mach Discussion => Mach Screens => Topic started by: slow-poke on October 12, 2017, 11:08:37 AM
I want to add a few LED's to an existing screen. I will have a brain drive the LED's. However the function of the LED is not a standard OEM type, I want it to be custom. My brain has output to OEMLED: 1001 etc.
How do I create a custom LED on an existing Mach3 screen that will turned on/off via my brain using for example OEMLED: 1000, 1001 etc???
Using MachScreen, when I select an LED, It seems like I can only select from the provided list of standard LED's that already exist on the mach3 screens.
if you are using MachScreen as your screendesigner, select the LED and enter your ID in the OEM-Code line of the property dialog.
Klaus
