Mach Discussion => General Mach Discussion => Topic started by: sawduststeve on October 10, 2017, 03:25:03 PM
I've been using this machine with Mach 3 and Gecko G540 for almost a decade. This problem may have occurred before, but isn't every time. Today the code was created by Vectric V-Carve Pro 9.0. After setting the X0, Y0 and Z0, I went to run the code. Z always goes to home position first, but it went past the limit switch and stalled mechanically. Letting the code run had Z go too low, past tabs and into the table. It seems the stalling affected the Z0 setting position.
I went to the toolbox screen and the limit switch is working. If I use "home all", it works just fine and does not mechanically bottom out.
X and Y do not "home" at start of code, just Z. Is this something in Mach or with Vectric?
When things work, I don't tempt fate. What is the intent of line 140: N140 G00 G43Z1.7424H1
The G-Code is as follows;
( File created: Tuesday October 10 2017 - 02:03 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 9.875, Y= 4.250, Z= 0.755)
(Toolpaths used in this file:)
(Profile 1)
(Tools used in this file: )
(1 = End Mill {0.25 inch})
N100G00G20G17G90G40G49G80
N110G70G91.1
N120T1M06
N130 (End Mill {0.25 inch})
N140G00G43Z1.7424H1
N150S18000M03
N160(Toolpath:- Profile 1)
N170()
N180G94
N190X0.0000Y0.0000F35.0
N200G00X1.5456Y3.1342Z0.9550
N210G1Z0.5033F30.0
N220G1Y2.6407F35.0
N230G1Y2.0157
Steve.
I found something. If I set Z0 as the last item, then zero all and run the code it all works. For some time I had had it run from multiple points and Z would home, but not mechanically hit, and it run properly. Maybe lucky those times.
It still seems odd that only the Z would try to home and go past the home limit switch.
Steve.
The real problem was the CAM software was putting in a "safe Z" higher than my axis was able to move. So it went through the limit switch until a mechanical crash trying to get to the "safe Z." I corrected the CAM software and all is good.
