Mach Discussion => Mach4 General Discussion => Topic started by: redpiperbob on September 28, 2017, 10:49:02 AM
Hi all
I wonder if I am missing somthing in the set up of the probing screens. I am having problems with Mach 4 probing.
First of all my probe works fine mach 3 with PobeIt and with Art's routines.
I am using the same milling machine and comuter with both Mach 3 and 4.
when I run the calibration in mach 4 the probe hits home once then comes up with "error probe not touching".
I am running in metric and have converted the default settings in the Probing Calibration Mach4 video to mm
I am probiing a 25mm dia inner bore.
I am using Mach 4 Ver 4.2.3481 ESS ver 210
Bob
does the probe LED on the diagnostics page come on when the probe actually strikes?
Hi Craig
yes the probe light on the display does light
I have attached a veiw of the status list
Bob
Sounds a lot like noise/bouncy switch to me. Not sure if you can add some filtering for the probe input in the ESS config. but think you can and should by the sounds of it. Even if the LED looks good it can all be processed, checked and reporting the error before you can begin to think about it, much less see it.
when I looked at the status messages I guessed that this probing operation must involve a couple of moves, am I correct?
Looks like the probe travels to the right say to find one inside edge, which it does successfully and then travels to the left to find the other edge at that
fails. If this is indeed the case I suspect that the 'wizard' which is generating the movement codes is crook rather than the probe itself.
Sounds like it's touching during the probe move (which ends the probe move) then checking to see if the probe is active (which it won't be now I'm guessing) so it can continue or give an error (no contact with probe). Just an educated guess though.
Hi Chaoticone,
very clever bit of guessing...would explain symptoms to a tee.
Hey Craig,
When I wrote the touch module I ran into the same thing when trying to simulate.
Hi Chaoticone,
always forget that the most active contributors to the forum actually develop Mach 'in their spare time' like.
You wrote the probing module, kool, very kool, but don't you have other and better things to do? You poor sick little puppy! LOL
;D
No, I did not write the probing module. I wrote the touch module. 2 completely different modules. I did not make the video at the following link either but it is about the touch module.
https://www.youtube.com/watch?v=VA49atQNzmg
Hi Chaoticone
Thanks for the reply (sorry for the long wait inrepling working away)
I will have a look into the noise thing it is the only conclusion I could come up with.
Bob
