Third party software and hardware support forums. => CS-Lab => Topic started by: Kaboomguy on September 03, 2017, 08:39:55 PM
I have converted my Techno-isel with the H26T56-SRVBOX2 amplifier using a CSMIO/IP-A. If there is interest on how I did it I will make a how-to on it.
Hey Kaboomguy, my name is Dave. I recently bought a techno cnc router table with the same servo control box that you retrofitted. I have been searching all over the web for info on an elegant solution to replace my missing pci card for this machine, and have put particular attention on mach4 based solutions as I already use that software on another machine. I am looking at the CSMIO/IP-A product page and this unit is a good bit more money than most of the other hobby grade conversion boards so I wanted to make sure that it's actually necessary. I assume that is because the analog encoder I/O is necessary to properly run these drives and that looks to be an expensive feature. Any feedback or insight would be greatly appreciated. -Thanks
