Mach Discussion => General Mach Discussion => Topic started by: DennisCNC on June 26, 2007, 12:13:09 AM
Im putting together a cheapo computer from parts that I have around to run a small router. And it has onboard video, so I ran the driver test and it was ugly! So installed a cheap ATI video card and looks like Mach will like this computer now. It's a Celeron 1.1Ghz just enough to run Mach. 8)
I have had the same problem in the past :(
Glad to hear that you got it working!
Some mobos with onboard video seem to work fine, but also had a few that like yours were horrific in the drive test. I think the ones I had that were OK had nForce chipsets but whether other mobos with the same chipsets would be OK is a case for trial and error :(
