Mach Discussion => General Mach Discussion => Topic started by: Katoh on May 24, 2017, 04:05:43 AM
Hi all
I just fitted up an AC servo as the spindle drive motor on a lathe, after a few exhausting days finally have something to show for the effort. All works well but has one issue that I am unable to resolve, anywhere from 0 to 1/2 its speed works like a charm but when asked to go higher the motor just will not respond, no spindle moment at all.
The lathe is controlled with a smoothstepper ESS, I have looked at the configuration and motor tuning but cannot see anything wrong.
The motor is rated 0-2500rpm anywhere from 0-1250 rpm is right on the money anything over just kills the spindle at 1260 programmed will get you 700rpm at 1270 300 and higher is 0.
In motor tuning I have the steps at 10,000 Speed at 2500 and acc at 40 Using Step/Dir as the output mode. Pulleys are et pulley1 0-2500 only one active. Smooth stepper spindle setting is at 500kHz.
If I try and use even different figures I still only end up with half that speed.
Any ideas?
sounds like the servo drive is interpreting your pulses as CW/CCW or quadrature rather than step direction.
Hi Craig
I checked and double checked and couldn't find a thing, I tried doubling the speed in Mach but still when it hits that magic 1250rpm and anything over that just slows to a stop.
One interesting thing I did notice is after that when you turn the spindle off or M5 its starts and then stops. What I am saying is anything with over 1250 rpm will start the spindle, wind it up to 1250 then stop, then its the opposite when you turn off.
Here is a pdf of the manual maybe I’m reading it wrong, not the first time.
do you have a scope? If so probe the pulse input to the drive and confirm th pulse rate, should be 416 kHz with 10000 count per rev and 2500rpm.
Check parameters 4, 8,9 and 10 for correct setup.
P4=0 for position control
P8=0 for step/direction
P9=1 gear ratio numerator
P10=1 gear ratio denominator
What have you set P20 to? Should be set to rated speed. For some reason P62 is also rated speed.
Let us know what you find.
Hi Craig
Thanks for the help!
No I don’t have a scope but I can tell you the parameters you mention are exactly what they should be, I even double checked just then.
P4=0
P8=0
P9=1
P10=1
P20=2500
P62=2500
It just seems so strange that its exactly half of the rated speed, If it was fluctuating or higher or lower than half it would lead me somewhere, but half? The only thing I think of maybe because I am only using 5V on pins 18-19 (+) side of step and direction but I can not see that as an issue as its step and direction controlled, not voltage.
Something I just stumbled on then, page 5 shows drive specifications and in the step and direction part has max frequency: Differential motion 500Khz and open Collector 200Khz
With motor tuning set at, steps at 10,000 and vel. 2500 gives me 416,667 steps/second = 416Hhz, If the drive is reading in open collector mode that’s double its maximum.
Problem is I don’t know enough about it to know what the difference between differential and open mode is to say that’s it, nor how to change it.
Bugger!
I think I have found the issue, I may need to use a Differential line driver, to convert the single ended line frequency to double ended.
Instead on using 5v to pin 18-19 and the step and dir to 6-7 which apparently is open drive only giving me 200Khz input max, I need to convert this to differential (Step + and -) and (Dir + and -) which will give me 500Khz input. looking around I found these.
http://www.shop.cncdrive.com/index.php?searchstring=Differential+line+driver&x=6&y=7
Might be the answer?
Welcome to the wonderful world of servos HaHa.
Hi.
yes you'll need a differential line driver to run at full speed at max resolution but you don't really need to do you?
I mean that currently with 10000 count per rev you can drive your spindle to location 2.16 arc minutes apart.....might be appropriate
for a ballscrew on an axis but do you need it for a spindle?. If not then use the electronic gearing to reduce the resolution to something
sensible, say 15 arc min, and you'll probably run single ended OK.
P9=1
P10=10
for gear ratio 10:1, ie 1000 count rev for a pulse rate of 41.66 kHz at 2500 rpm.
Hi Craig
Yes I can see exactly what you are writing about, and that will work!
The only situation I see now is I also have the same motor connect to the spindle to work as a "C" rotational axis as well as a spindle. I was thinking all good when I read your post but then remembered I changed the Parameter 9 and 10 setting, where with the "C" axis you would want as much degree of accuracy as possible, But then just thinking about it now, If I use 27.7steps/deg and vel of 3600 in motor tuning for "C" axis I should in theory still have a location of 2.16min/step and a speed of 100rpm max with the parameter 10 set at 10. If that makes any sense?
Many thanks for your reply, I think you really hit the nail on the head
Theo
yes, I understand what you mean. The problem is that you can't change that parameter on the fly,
ie you can't use Mach to change it and then change it back after you're done unless the drive manufacturer
has allowed you to program parameters while in service.
To be honest if your machine is accurate and rigid enuf to require C axis resolution of 2.6 arc min then you
obviously have LOTs of bucks, why piss about with Mach4? Time to get real about what you want vs what
you can achieve within your budget/expertise.
I have recently made a mill spindle with a 1.8kW servo. I will at some stage require an indexing spindle for
rigid tapping, but not 2.6 arc min!!! 15-20 arc min will be plenty good enuf for me. In the mean time
all I require is speed control, and not much of that...max spindle speed is 3500 rpm. Unless I use a large diameter
facing tool I set it to 3500 rpm and leave it there. Saves a lot of messing around to achieve little except bragging
rights. Man does this spindle make chips...glorious chips!
Hi Craig
Once Again many thanks for your assistance, your help is so much appreciated and you don’t realise how much you have helped me out.
I will be total honest and yes I agree with what you said. Firstly to start with I don’t have the BUCKS :-X wish I did then I could get things done, I’m purely a bargain hunter, but do spend on what I need too. I actually started this lathe build 6 years ago and have slowly bean updating as I go.I built my Router 4 axis back in 06, now back then it was cutting edge, but I built it from the ground up with what I could find at the time. Back then manufactured machines where in the 100's of thousands of dollars to buy it was a good build and has paid itself off many times over, actually I still use it to mill parts for my other projects now. I started a mill conversion 5 years ago funny thing is its 90% done with everything here ready to go to complete, Ill talk about that one soon.
My issue and I really hate to admit this possibly I could be a little "OCD", I have trouble with knowing that if something can achieve say good precision when I know it can achieve great precision even though none of the other components are that capable of that precision. This irritates me, it gets under my skin and I’m simply not happy till it does what I want! Funny thing is I know its totally impracticable and not needed but for some reason if it can do it I want it to do it, or its simply not doing its job.
Sounds like a nice mill. I am re-ferbing a Bridgeport, when I bought it for near nothing it was was somebody else's project from a local uni, the mill hardy has done any work but the nice thing was they already went to the trouble of fitting ball-screws that really was my big bonus. I have X and Y setup ready to go, I am just rebuilding the spindle (bearings ect) bringing it all back to new. What I am using for the spindle drive is an after market 2.2kw induction motor VFD controlled 1:1 timing belted to the spindle. Here is the crunch I have made up a independent slide unit that turns a 2000line encoder directly from the drawbar, tools are changed with a QC so no need to access the drawbar at all. This again gives me 2.7min/step and feedback even if using the backgearing. The other thing I have chosen to use Vitalsysetems interface as the controller, this has bean my largest expense to date just the controller, everything else was bargain basement.
from one OCD to another....yeah I got you!
My mill is homebuilt. I used cast iron elevator weights to mill the axis beds. 15mm linear rails and cars, C5 20mm ground ballscrews,
5 phase steppers with low backlash planetaries and German made 1hp 24000 rpm spindle all bargain hunted off Ebay.
Machining volume is very small, 190x190x190mm. Amongst the things that I wanted this machine to do is make circuit boards and
it does so really well. In addition I wanted to be able to mill steels and other tuff stuff. The high speed spindle is hopeless at that.
The problem with milling steel or stainless is that you need relatively low surface speed but plenty of torque. I hadn't appreciated how
whimpy the torque is from high speed spindles is.
That's what lead me to making a slow speed spindle necessary to spin 1/2-5/8 inch endmills in steel. Budget precluded me from
buying outright or even having a precision engineering company make it for me.
I've had to learn that despite my wanting a certain thing or level of precision I can't achieve it, be it budget, skill, machining capability
and the list goes on. I've come to realise also that if I insist on a certain standard say then I may in fact prevent myself from doing anything!
This spindle is a case in point. I did buy a genuine RegoFix ER25 cylindrical tool holder and matched NSK angular contact bearings. The
problem was that I wanted it to be perfect, or as near to it as I could get, and yet couldn't afford to have someone else make it and with
the lathe I have access to and my skills suggested that if I did it myself it was going to be less than perfect. I had talked myself to a standstill.
I eventually did break thru that nonsense and did make it myself. Surprise, surprise, its not perfect! On the other hand its not to bad either,
in fact its better than not too bad, I'm rather proud of it! It works a treat, enuf torque to drive just about any tool I can fit in it and certainly
more than my machine is rigid enuf to contain the cutting forces. TIR=0.01mm, not as good as I hoped but not too bad and it certainly works.
All up including the Allen Bradley servo, servo drive, toolholder, bearings and seals plus some extra tooling for the lathe $2000 NZD.
Sometimes you've just got to overcome that OCD thing and get on with it, this example is a good one for me.
HaHa! Yeah I sometimes think it is prerequisite that you must have some sort of mental condition to play with stuff in the first place!
Wow built your Mill, and Lathe, Hats off to you Sir!
I thought I was good with the router, but mind you its a bit of a beast, 3m long 1.8m wide 350mm in Z and has 1200mm "B"axis down the bottom for turning work. Gantry is all Aluminium plate on a prime mover bull section the rest of it is mild steel, It runs twin 900 steppers on each axis, not quick but quick enough for me.
The lathe again I was really lucky with, Hare and Forbes (machinaryhouse) in Sydney had these lathes that where fitted up with wrong motors, and sold them non motor, I bought one at a generously discounted prise, $800Au new lathe 280x750mm when it arrived I simply stripped it and only used its base and head and tail units altered the cross slide to fit a 12mm X ballscrew and a 20mm Z ballscrew driven by 500oz steppers. Was induction motor and vfd driven till 4 weeks ago now servo spindle with ESS. Don't get me wrong it was fantastic before but now I think better.
Theo
