Mach Discussion => Mach4 General Discussion => Topic started by: rrc1962 on April 17, 2017, 05:03:36 PM
Is there something behind the scenes that prevents this function from executing during a program run? I have a macro that I want to call that moves X and Y to a specific location, then zeros the DRO's, re-paints the toolpath display and continues on. Everything works, but the toolpath display doesn't regenerate when mc.mcToolPathGenerate(inst) is called.
It will only work in the idle machine state. :( Why, because it uses the interpreter to generate the tool path. So running the interpreter to run a file and generate a tool path is definitely mutually exclusive.
Steve
