Mach Discussion => General Mach Discussion => Topic started by: CNCDK on April 08, 2017, 11:49:55 AM
How I made so I can use an input to "Feed Hold" ??
I have input available on my bob (P13)
Goto config - inputs
Scroll down to oem#1
Assign correct port / pin
Then goto config - system hotkeys
Assign feedhold number from Hoods list above.
The number is in the 1000's
Save
Run
olf20 / Bob
Hi
can you describe in a better way how I do after this ??
Save
Run
If you look at page 8 of Hoods OEM CODE List.
Open it with a spreadsheet program.
Scroll down to the 1000's and you
will see 1001 is PAUSE or feedhold.
This is the number you enter for the OEM Code #1
on the right hand side under System Hot Keys.
Of course you have to assign your port and pin
number to INPUT #1, under Configure, Ports & Pins,
Inputs.
Hope this helps. It is a little confusing and I may have
not explained it the right way.
Post back if you get hung up.
olf20 / Bob
1000 thanks
