Mach Discussion => Mach4 General Discussion => Topic started by: gorf23 on April 03, 2017, 03:54:58 PM
is there a way to use require() in a lua script without having a file dialog box loaded, or is that another lua command to do the same call without a file dialog box.
It seems to works for calling a lua script from another lua script and being able to pass variables just don't want to wait to pick the file...
thanks
The require function is to load modules, take a look in the Screen Load Script and see how its being used there.
DazTheGas
Thanks daz
I used some code form the load screen script it works, it will load my module and run it... But it always pop's up a file dialog box i have to pick the file and click ok
I just want the module to load and run with no file box...
This is a path issue. If lua can't "find" your module, it will ask you where it is via the file dialog. Make sure the module's path is in the package.path.
Steve
