Mach Discussion => General Mach Discussion => Topic started by: CNCDK on February 11, 2017, 10:38:54 AM
Hi
Can you see what data should be as standard in the motor turning ??( For mach 3)
I have X Y X axis stepper motor 23HS8430
May I suggest that you have a read of the manual as that covers how to determine the steps per unit.
Next just do a search and you will find how to determine the max velocity and acceleration.
You will also find info in Members Doc's.
Still have problems reply back,
Where can I find docs about it ??
MACH3 MANUAL
http://www.machsupport.com/help-learning/product-manuals/
Mach3 Mill Installation and Configuration Guide .....(Read Chapter 5)
http://www.machsupport.com/wp-content/uploads/2013/02/Mach3Mill_Install_Config.pdf
MOTOR / STEPPER TUNING
http://www.machsupport.com/forum/index.php/topic,17600.msg120928.html#msg120928
STEPS PER UNIT MATH EXAMPLE
http://www.machsupport.com/forum/index.php/topic,12512.msg81001.html#msg81001
STEPS PER UNIT CALCULATOR
http://www.machsupport.com/forum/index.php/topic,16315.msg110286.html#msg110286
