G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: nose on June 12, 2007, 01:44:42 PM
i been working on this drawing in corel draw and opened it in lazycam and it seems to have rapids going all over the place and i cant move the lead ins hope maybe one of you guys can take a look at it and tell me what im doing wrong!
thank you for your time
Hi, Nose
Waited some time four your file to load never finished hear.
Loaded it into Turbocad 8 Grouped All saved loads hear now.
Hears the New dxf, NC and Lcam files, Give them a try.
Hope this Helps, Chip
im sorry i guess i didnt specify like a dummy this is a plasma project sorry for the confusion thank you for your time and help chip i really appreciate it
here is a different file seems to load better and yet it still does the same
Hi, Nose
Hears a couple of files, The biggest problem with your file is there are many unconnected and non trimmed overlapping lines.
There are some issues with LCam picking up line segments that are grouped also.
This is a work in progress, There are some import options that are being worked on by an outside vendor for LCam.
Hope this will Help, Chip
thanks again chip! it deffinetly helped i sorta thought it was a little too sloppy
