Mach Discussion => Mach Screens => Machscreen Screen Designer => Topic started by: leversole on January 15, 2017, 02:57:18 PM
Title: Main Screen Disapearance!
Post by: leversole on January 15, 2017, 02:57:18 PM
Suddenly, the main window in Mach Screen disappeared?!? Only the properties window shows…I rebooted, uninstalled, reinstalled ver 64 (was using ver 66)…still whenever I start Mach Screen the main window loads for a split second, then disappears, leaving behind the properties window…
Even looked for a registry setting, cannot figure this one out...
Any ideas?
Thank You
Leslie
Title: Re: Main Screen Disapearance!
Post by: Klaus1311 on January 15, 2017, 04:22:43 PM
Hi Lesli,
To fix that problem please terminate MachScreen, press the „Shift“ key und hold it pressed down, start MachScreen while keeping the “Shift”  key pressed. That puts all MachScreen settings to default.
Klaus
Post by: leversole on January 15, 2017, 06:24:52 PM
Thanks...will try it out tomorrow...watching football and eating wings right now!   ;D
