Mach Discussion => General Mach Discussion => Topic started by: tlittler on December 27, 2016, 05:22:26 PM
Is there a test I can do to make sure MAC 3 and my Ez Router r communicating together? nothing happening when i click Reference all home.
Thank You.
Anything? think of testing the parrel port out put. Not sure how to do this.
First step is to run DriverTest.exe (Mach3 folder).
Does this run correctly ?
Post you .xml file (<your profile> .xml ) then we can check your settings & look for possible errors. You need to copy the .xml file from you Mach 3 folder then rename it to tlittler.xml then use the Additional Options... to attach to your post.
tryed Driver Test .exe
Does nothing.
Having a person from IT come and take a look.
Thank you
Something to consider...
Mach3 will run on any Windows OS from Windows 2000 through Windows 10. The parallel port driver included with Mach3 will only work with 32-bit DESKTOP computers (Laptops are not supported) with versions of Windows 2000 through Windows 7, but will not work with any 64-bit version of Windows or with Windows 8. Windows 8, 10 and 64 bit versions of windows require an external motion device which can be purchased very reasonably.
Tweakie,
Please clarify. What is the "external motion device which can be purchased very reasonably"? And where would I look for them? I'm trying to sale my CNC Router and building a Joe's EVO CNC. I have a PC I can use on the EVO but it is 64bit.
Tweakie,
Here are just a couple that come to mind…
UC100 http://cncdrive.com/UC100.html
SmoothStepper http://warp9td.com/
But, there are many more to choose from.
(Please be aware that the very cheap Chinese motion control boards may not support all the Mach3 functions and also backup / support / software and firmware updates may not be available).
