General CNC Chat => Share Your GCode => Topic started by: TonyPerthWA on November 08, 2016, 01:40:10 AM
Hi
My machine is still in transit but I have been playing with the demo of Mach3 to try and familiarise myself with it.
I would like to use the machine to carve the logo for the motorcycle group I am in here in Western Australia.
The machine I have purchased is the 3 axis 3020 CNC Router engraver
I would like to ask is the attached file too difficult or complex, both for me and the machine?
I will attach the jpg along with the dxf file.
I know I will be learning a lot in a short time but if someone could advise if its too difficult a job and perhaps even translate it into gcode, ready to run in Mach3
I can hand carve this logo with a reasonable accuracy over a couple of days however it still looks amateurish.
Any help offered will be gratefully accepted
Hi Tony,
Unfortunately your .dxf was not uploaded correctly, perhaps you could try again.
The .jpg you have provided is not that good a quality for me to produce a reasonable .dxf without an awful lot of correction work.
I don’t think the logo you have chosen is too complex but it may be wise for you to start out with something real simple until you get the hang of using your machine and all the software’s involved. Bear in mind that Mach3 has a 500 line Gcode limit when operating in Demo mode.
Once you get a good vector drawing (.dxf) then there are many software’s (some free, some paid-for) which will generate a Gcode engraving toolpath then away you go on the great CNC adventure.
And what a life long adventure it will be!
DXF doesn't open here for me either.
Thanks guys. I will try again in Illustrator and see if I can improve
Ok so I think I may have a file that looks ok but without a machine yet (December 3) I really cant have a go. Also, since I have the demo of Mach3 I cant run the full gcode. It seems to load in the preview window of Mach3 Mill however with the 500 line limit, I cant really do much. Willing to download a license if this will run. What I would like to do is get rid of the bounding box around the design. Just wondering if someone could take a look at it and see if it will run
Yes, your Gcode runs. It outlines the box in two passes. Then it moves to, presumably, the start position although it takes 24 lines of code to do what 1 line of code could do. Not sure why you have all the G40, G42 codes at the end when just one G40 would do. You need to finish your Gcode with a CR and the common way to do this is finish with the % character as the last line of code.
One additional comment…
There is no right or wrong way but it is usual to have X0, Y0 at the bottom left of the workpiece. It is also usual to have Z0 as the surface of the workpiece ( –Z moves the cutter into the work ).
Hope this helps,
Perhaps someone could do me a huge favour. Im still struggling with LazyCam because even when I ceate a dxf file I cant see it and it generates no gcode. I am wanting to do a project for an army mate. Its the rising sun bade worn by Australian soldiers and I wanted to carve it and present him with it for Christmas, however no matter how I go about it, I just cant seem to get it to write the gcode from LazyCam.
Could someone please take a look and post the gcode here for me as I am getting pretty frustrated. Im ok with Mach 3 and can navigate the machine part of things, I just cant seem to generate the .tap file needed.
The image can be found at
http://medalbox.com.au/images/bitmap%20in%20graphic1.bmp
If anyone could help I would really appreciate it
If it’s any help to you I have converted your bitmap to a vector which can be loaded into LazyCam (It takes a while to load).
The LazyCam manual can be found here http://www.machsupport.com/forum/index.php/topic,12078.msg77415.html#msg77415
LazyCam is not the best of tools to be using but it works.
Thanks Tweakie. When you say it takes a while to load, does it take minutes? I usually give up after 20-30 seconds of load time. Perhaps this is my problem. Will let it run for longer and see how it goes
I suppose it depends on the PC processor speed but I have had files, in the past, which have taken best part of 1 minute or so to load. :)
What are you creating the .dxf in, and what version .dxf is it? Many programs don't properly support the .dxf file format, which leads to other programs not being able to read them. Different versions of .dxf can also lead to the same issue. Generally, you want to save in the oldest .dxf version that you can v12 typically being the most universal.
I work with Corel Draw for most of my carvings. (profile cuts in particular, imported into LazyCAM). The DXF file format just doesn't work for me. So after many hours of trying different files formats, when exporting them from Corel Draw, I discovered that the Hewlett Packard Graphic Language *.PLT file format is the one to use. As it preserves the correct aspect ratio, and actual dimensions of the drawings. When importing them into LazyCAM. (Instead of just clicking the "open DXF" menu item, click on the "File, Open vector file", and select the HPGL *.PLT file format, then navigate to the folder where your file is stored, and click on it to open). Works great for me. And has for the past 8 years!
adprinter,
Glad it works for you.
When creating the manual only DXF files were used and tested.
So not sure what bugs one would find if other file types are used.
I've made hundreds of military emblems and stuff. You can see some of the stuff that I've done in the video on my web site. Maybe you're interested.
http://www.cncproductionwork.com
Alan
Hi
