Mach Discussion => General Mach Discussion => Topic started by: Errolf on July 12, 2016, 02:46:04 PM
Hello
I have positioning problem in mach 3
there is a plasma table with NEMA 23 stepper motors and DM542A .
when I will cut out Components with inner contours is not
centered in the peace as DXF cad.
When I look at the details , it looks like the x-axis is moved between the cutting of inner and outer conturen.
What could I have done wrong . does anyone have any tips ?
///////Jim Persson
Just some things to check:
- Confirm drawing is correct.
- Confirm that the gcode is correct. ( post your gcode file and someone may backplot it to confirm it agrees with the drawing )
- If the above is ok then it may be that you are loosing position during a move or it's you machine .....
