Mach Discussion => VB and the development of wizards => Topic started by: abcncfab on June 24, 2016, 07:31:21 AM
Hi, I have written a m6start macro for my carousel type tool changer.
It works flawlessly 95% of the time but unfortunately rarely grabs a tool 1 position out.
Here is a copy of the macro.
ANY help would be muchly apreciated.
any questions about my macro im happy to answer.
Sub Main()
OldTool = GetCurrentTool() 'Tool In spindle DRO You must add this to your settings screen
NewTool = GetSelectedTool()
Z_changePos = -122 'z change position
Z_safePos = 0
MaxToolNum = 21 'Max number off tools for the changer
If NewTool = OldTool Then
Exit Sub 'exit if tool as same selected
End If
code "M5"
If OldTool >= MaxToolNum Then
Code "G00 G53 Z" & Z_safePos 'move z to carriage engage height
While IsMoving()
Wend
MsgBox " Please remove TOOL #" & OldTool & Chr(13) & " Then press OK to Continue"
OldTool = question ("Please enter current Tool carriage position then press OK to CYCLE START")
GoTo spindlecheck
End If
chuckCheck:
If IsActive(input2) = IsActive(input3) Then
While IsMoving()
Wend 'wait until its moved
Else
If IsActive(input2)=0 = IsActive(input3) Then
code "G00 G53 Z" & Z_changePos
While IsMoving()
Wend
End If
End If
spindlecheck:
If IsActive(input4) Then 'check spindle rotation input
GoTo engage
Else
GoTo spindleAlign
End If
spindleAlign:
code "M3 S60" 'correct spindle rotation
While IsActive(input4)=0
Wend
code "M5"
sleep(2000)
GoTo spindlecheck
engage:
SetOutBit(100,2) 'engage tool carriage
sleep(100)
ResetOutBit(100,2)
sleep(100)
While GetInBit(100,1)=0
Wend 'wait for engagement
sleep(100)
SetOutBit(100,6) 'engage power tool bar / tool release
While GetInBit(100,3)=0
Wend 'wait for draw bar engaged / tool released
Code "G53 Z" & Z_safePos 'move z to tool carriage spin height
Code "G4 P.75"
While IsMoving() 'wait for z to move
Wend
If NewTool >= MaxToolNum Then
GoTo NewTooltoobig
End If
CWPos = NewTool - OldTool 'calculate CW distance
If CWPos < 0 Then
CWPos = CWPos + MaxToolNum
End If 'invert number if minus
CCWPos = MaxToolNum - CWPos 'calculate CCW distance
If CWPos < CCWPos Then 'take shortest distance
GoTo CW
Else
GoTo CCW
End If 'goes to CW or CCW script
CW: 'CW count sequence
moved1 = 0
starting1:
SetOutBit(100,5)
sleep(50)
While IsActive(input1)
Wend
sleep(20)
While IsActive(input1)=0
Wend
moved1 = moved1+1
ResetOutBit(100,5)
If CWPos = moved1 Then
Wend
GoTo finish
Else
GoTo starting1
End If 'end CW count sequence
CCW: 'CCW count sequence
moved2 = 0
starting2:
SetOutBit(100,4)
sleep(50)
Wend
sleep(20)
Wend
moved2 = moved2+1
ResetOutBit(100,4)
If CCWPos = moved2 Then
Wend
GoTo finish
Else
GoTo starting2
End If 'end CCW count sequence
NewTooltoobig:
SetOutBit(100,3) 'disengage tool carriage
sleep(100)
ResetOutBit(100,6)
While IsActive(input3)
Wend 'disengage power draw bar / tool clamp
ResetOutBit(100,3)
sleep(100)
While GetInBit(100,0)=0
Wend 'wait for disengagement
sleep(100)
MsgBox " Please insert TOOL #" & NewTool & Chr(13) &" Then press OK to CYCLE START"
sleep(500)
SetCurrentTool(NewTool)
GoTo theveryend
finish:
Code "G00 G53 Z" & Z_changePos 'move z to carriage engage height
While IsMoving()
Wend
ResetOutBit(100,6) 'disengage draw bar
sleep(600)
If IsActive(input2) = IsActive(input3) Then 'check for good tool clamp
DoOEMButton(1021)
SetCurrentTool(NewTool) 'reset mach and give fail message
MsgBox "TOOL CLAMP FAILURE "
Exit Sub
End If
SetCurrentTool(NewTool) 'changes current tool DRO
sleep(100)
ResetOutBit(100,3)
sleep(100)
sleep(100)
theveryend:
code "G43"
sleep(250)
End Sub
Thanks very much in advance!
Ben Smith ??? ???
Im thinking my proximity sensor on the carosel might be just on the borderline of detecting the moves. Ill try move it a tiny bit closer and see if it fixes the problem
ok its not the proximity sensor :(
