Mach Discussion => General Mach Discussion => Topic started by: BlackBox on June 10, 2016, 08:03:52 AM
Title: Smooth movement while motor tuning, stall when jog
Post by: BlackBox on June 10, 2016, 08:03:52 AM
First post. Been using Mach3 for a couple of years with Gerry's 2010 screen set on my large router. Awesomeness!
Today I have a problem. I am converting my small CNC router to be Mach3 compatible via parallel port. I removed the USB motion controller to use it on another machine.
When I do the motor tuning the axis moves smooth as expected - I have tested a range of velocities and acceleration all with no problem.
As soon as I close the motor tuning window and try to jog or run gcode the axis moves with grinds, jerking and stalls.
Any ideas?
Title: Re: Smooth movement while motor tuning, stall when jog
Post by: Tweakie.CNC on June 13, 2016, 01:49:52 AM
Run the Driver Test (Mach3 folder) and see if the results are OK.
Post by: BlackBox on June 13, 2016, 02:51:06 PM
I did. Not 100% sure what I should be looking for? It says system excellent but apparently that is not a real indication? The line is flat but not super smooth, at 25kHz it has small bumps all over, at 100kHz only a few.
At 25kHz I get max variation between 3 and 7us.
At 100kHz between 2.4 and 3.0us on average.
I am running on a Win7 32bit box. My other machine runs on XP. I tried the Vista registry patch but it did not make a difference.
Thinking I should try another PC, maybe see if I still have an XP install...
Post by: joeaverage on June 16, 2016, 08:17:06 AM
hope this does not upset you.. but I want to ask that when you go back to the motor tuning page whether
the settings you had previously made are still there.
When I was learning this stuff I on too many occasions would forget to 'save axis settings' before moving on
and then scratch my head when the axis movement didn't appear to change. I mean how dumb can I get!
In more recent times I don't change those settings often if at all and if I did would still too often forget to
do so!
Post by: BlackBox on June 16, 2016, 05:00:50 PM
Not at all. Thanks for the reply.
motor tuning page whether the settings you had previously made are still there
Yes they have been saved. I have made this mistake before but not this time...
