Mach Discussion => VB and the development of wizards => Topic started by: bigk on June 03, 2016, 05:00:07 AM
Hi is it pauseble to check for input2 only when the program is finish with input1.
it should be when input1 is active work offset 10 should be used and after program stop if input2 is active work offset 11 should be used and start program and so on.
If isActive (OEMtrig1) Then
message "Start Program"
DoOEMButton(1002) 'Reset Gkode
Sleep(100)
If IsActive(Input1) Then
message "OFFSET 10"
SetOEMDRO(46,10)
'Code"G59 P10"
Sleep(100)
DoOEMButton(1000) 'Start program
While IsMoving()
Wend
End If
Sleep(100)
If IsActive(Input2) Then
message "OFFSET 11"
SetOEMDRO(46,11)
'Code"G59 P11"
Sleep(100)
While IsMoving()
Wend
End If
Sleep(100)
If IsActive(Input3) Then
message "OFFSET 12"
SetOEMDRO(46,12)
'Code"G59 P12"
Sleep(100)
While IsMoving()
Wend
End If
Sleep(100)
If IsActive(Input4) Then
message "OFFSET 13"
SetOEMDRO(46,13)
'Code"G59 P13"
Sleep(100)
While IsMoving()
Wend
End If
message ""
End If
