Mach Discussion => Mach4 General Discussion => Topic started by: Bx3mE on May 28, 2016, 11:22:35 AM
I have Smoothstepper setup and have run it With pmdx 126 for a while now.
I am configuring my CNC for use with an Engraving Laser Diode.
To control my Laser Driver i have three signals: Driver On, Beam On and Beam Intensity (PWM).
I want to control Beam on using M62 P0 (Followed by a Move Command G1 X...)
I have tried different connections on the pmdx Port#1Pin#1, Port#2Pin16 and 17 but non seems to work.
Further investigation using the diagnostic screen shows that Output 0 Never toggles to On..... No matter of hardware configuration this should toggle right? Im running build 2914 of Mach 4.
Can anyone point me in the right direction? ??? ???
M62 is not yet implemented in the Mach4 Plugin.
DazTheGas
Reading from the Warp 9 site: http://warp9td.com/index.php/faq/faq-g-code-m-code
The commands are as follows, with x referring to digital output 1, 2, 3, 4, 5 or 6.
M10Px Turns Output x OFF with subsequent motion command. Used in Mach3. (Logically backwards.)
M11Px Turns Output x ON with subsequent motion command. Used in Mach3. (Logically backwards.)
M62Px Turns Output x ON with subsequent motion command. Used in Mach4.
M63Px Turns Output x OFF with subsequent motion command. Used in Mach4.
Very confusing....
I have just spent good 20 hrs to fix this... Is there another good way?
I think that could be refering to mach3
DazTheGas
Yes but on the same page he refers to a mach4 sample...
"Make sure your G-Code includes M11P3 or M10P3 (the 3 indicates output #3) commands followed by a move command, like this Mach3 Example or this Mach4 Example."
But still - is the output LED Icon in the Diagnostic screen dependent of the plugin?
Don't feel bad. I've been all day trying to figure out why 1 does not equal 1 in an M code. Frustrating when things work fine in the editor, then go south when you run it in MDI with no error messages.
I can't speak to the ESS plug-in and whether or how they implement M62/63. I *think* that signals controlled via M62/63 will NOT have their status reflected in the indicators on the diagnostics tab until the current MDI or GCode file has conpleted. If I remember correctly, the reasoning was that the Mach4 core does not know when the signal is actually turned on or off by the device. I am not at a PC where I can test this, but that may explain why the diagnostics tab indicators never turned on.
Bob
Assuming you are talking about the diagnostics page in one of the default screens (wx4 or wx6), the output leds represent the state of output signals (the only thing Mach4 controls). If your looking for the status of hardware pins you will need to look at the SmoothStepper (or whatever hardware your using) diagnostics.
ESS diag page
Thanks all for your input - im leaving this issue open until M command is implemented in ESS plug-in.
