Mach Discussion => Mach4 General Discussion => Topic started by: Kiamer on May 08, 2016, 02:12:53 PM
Hi everybody,
im actually testing Mach4 version 4.2.0.2914 with CSMIO/IP-S (firmware v2.851). Everything works well so far but only one thing is strange! When i load G-Code all axes will be automatically de-referenced.
Is this a known bug in this Mach version?
Hopfully someone can help in this case.
Maik
Try this with the SIM (simulator) plug-in as the motion device. Do you still get the deref when you load the GCode file?
Bob
In simulation mode it works fine!
I checked CSMIO-Plugin configuration and find out in Special Funktions/Other/Axes DeRef & Zero the value "Set Axes to "0" on Reset" was selected. After deselecting it works also with CSMIO as the motion controller.
Not sure why loading G-Code create this "reset" signal. In Mach3 for example it works when i select this option!
Maik
