Third party software and hardware support forums. => PoKeys => Topic started by: slizys on May 01, 2016, 09:36:10 AM
Hello
I am very new at this.
I have got 2 phase Nema 34 type motor + encoder and driver for it. (Motor is 12Nm holding torque). Please see attached photos.
(http://i68.tinypic.com/2yl4ugw.jpg) (http://i63.tinypic.com/b49ff8.jpg)
Please Find attached Datasheet for HSS86 Driver:
http://cncdrive.com/datasheets/2HSS86H.pdf (http://cncdrive.com/datasheets/2HSS86H.pdf)
(http://i67.tinypic.com/ok7wbt.png)
I have wired Pokeys57CNC and my Hss86 Hybrid servo driver like this:
(PUL+)Hss86 ------> Step (Pokeys57CNC)
(DIR+) Hss86 -----> DIR (Pokeys57CNC)
(ENA+) Hss86 ------> AXenable (Pokeys57CNC)
PUL- ; DIR- ; ENA -; --------- > GND (Mottor Connector Pokeys57CNC)
Is this Correct?
I have Installed Mach3 software and Pokeys Plugin for it. I have connected Pokeys57CNC via ethernet cable. Mach3 detected it.
I did these sttings in Match3.
Any Ideas Why Motor dont move?
(http://i63.tinypic.com/1214z1w.png)
(http://i64.tinypic.com/w2enok.png)
(http://i63.tinypic.com/10sgpqf.png)
(http://i66.tinypic.com/mbub6r.png)
Thank you for your Help
Make sure that you select 'External 4ch with IO' as Pulse engine type in the PoKeys plugin configuration.
I have set ''External 4ch with IO'' as NeoTo suggested, but Still nothing :(
Any other suggestions what I did wrong, got a feeling it is going to be such a small thing.....
have you moved the power selector jumper
If I get you righ and you mean this jumper:
Yes I did as in this photo. Also I have connected 12Vdc 1.0A externl power supply. Motor dont move :(
(http://s32.postimg.org/r5jnekisl/Power_Supply_Jumper.png)
is the E stop working, post your config.xml
E stop is working, I can Run sample G Code, on Mach 3 screen it shows that X;Y;Z Axis moving, but motor dont move. Checked motor it gets power and etc, and it seems he is waiting for command, he holds its current position (I have tried to move shaft with my hand could not manage to do it when system is on) I can move it easily when power cable is of.
Please find attached my config file.
To View File press here
****View****My Configuration file**** (http://slizys.comxa.com/Pokey57CNC%20Plugin%20Settings.xml)
Or
Download File press here
*****Download file ****My Configuration file**** (http://mab.to/v3jTzbSW8)
Did you try checking 'Invert enabled output' in the plugin settings?
Thank you ! It is working :D
