Mach Discussion => Mach4 General Discussion => Topic started by: daduggan on April 19, 2016, 02:24:23 PM
I noticed after closing a Gcode file the extents remain and not cleared. I would think they are cleared when closing a file. The same goes for the tool path display showing the box from the extent settings.
Is there a function that can be called to clear the run timer? I have it displayed but no way to reset it.
And shouldn't it be cleared when a reset/rewind etc command is executed.
If there a function or a variable that can be cleared I can write a script to reset it as needed.
+1 FOR ME AS WELL. THIS DRIVES ME CRAZY
