Mach Discussion => General Mach Discussion => Topic started by: Fred_evans on April 15, 2016, 10:07:20 AM
Hello All
I am using the wizards and they work well but for some reason it is always setting the
feed at g94.
I prefer g95-
how can i get the wizaed always to use g95 instead of g94?
regards
fred
You will have to alter the script in the Wizard.
Thanks Hood- but how do I do that?
regrds
fred
Best idea is to copy the wizard just in case you make a mistake.
You will find it in C:\Mach3\TurnAddons\Turning If you just copy that whole folder then you will be able to place it back if something goes wrong.
Ok to edit the wizard you open the wizard from Mach then if you go to operator menu then Edit Button Scripts the Post Code button will be flashing, click it and the editor will open and you will see the code. Look for G94 and change to G95 and save and close, you should now get G95 when you post code from that wizard.
Thanks Hood-
Done and understood
Is the procedure for writing wizards documented anywhere??
Is it written in VB?
Regards and out
fred
Fred, not any documents that I know of. They are written in VB or rather Cypress and there is a manual for it/Mach on the website.
