Mach Discussion => General Mach Discussion => Topic started by: Statler on March 24, 2016, 05:43:54 AM
I have a problem with the tool table it concerns the tool table entries beyond pos 8
Machine: Retrofited Emcoturn 140 with a Sauter turret ( 8 Positions) running on Mach3Turn
Everything works fine until I want to use another tool in one of the tool positions. The tool offset from the tool table is only for a few seconds visible before it change back to the prior off set.
I am use several sizes of drills in Pos 4, the tool table entries are T0404, T0412 and T0420.
If I give the tools change command T0412 the correct Z value shows only for a second and it changes back to the value of the T0404 Z value.
Does anyone know a solution for this problem?
Statler
What version of Mach are you using?
May also want to post your macro / M6 / script for review.
Hi Rich,
Mach3 version R.3.043.066
I hope this is the script info you mean (from the M6start.m1s file)
Code "M200"
Sleep (3000)
NewTool=GetSelectedTool()
OldTool=GetCurrentTool()
MaxToolNum = 8
If OldTool<>NewTool Then
While Tool <> NewTool
ActivateSignal(Output3)
If isactive(Input1)And isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) And Not isactive (Oemtrig1) Then
Tool=1
End If
If isactive(Input1)And Not isactive(Input2)And isactive(Input3)And Not isactive(Input4) And Not isactive (Oemtrig1) Then
Tool=2
End If
If isactive(Input1)And isactive(Input2)And isactive(Input3)And Not isactive(Input4) And Not isactive (Oemtrig1) Then
Tool=3
End If
If isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And isactive(Input4) And Not isactive (Oemtrig1) Then
Tool=4
End If
If isactive(Input1)And isactive(Input2)And Not isactive(Input3)And isactive(Input4) And Not isactive (Oemtrig1) Then
Tool=5
End If
If isactive(Input1)And Not isactive(Input2)And isactive(Input3)And isactive(Input4) And Not isactive (Oemtrig1) Then
Tool=6
End If
If isactive(Input1)And isactive(Input2)And isactive(Input3)And isactive(Input4) And Not isactive (Oemtrig1)Then
Tool=7
End If
If isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) And isactive (Oemtrig1)Then
Tool=8
End If
Wend
If isactive(OEMTRIG5) Then
Sleep (100)
DeActivateSignal(Output3)
End if
ActivateSignal(Output4)
Sleep(100)
ActivateSignal(Output7)
Sleep(1500)
DeActivateSignal(Output4)
DeActivateSignal(Output7)
End If
SetOEMDRO(824,Newtool)
While IsMoving
Wend
End
Grtz Statler
